Good evening!
We noticed that our oven stopped baking. At first it would get up to only about 200F in preheat, but then when we power cycled, it worked. This happened sporadically, but then it stopped baking all together.
I was going to run some diagnostics to check the temp sensors, but I can't seem to get into the service mode. From what I could find, to enter test mode one must press "COOKING MODE", "TEMPERATURE", and "START" simultaneously for 5 seconds. I tried, but it doesn't work.
Is there a different way of getting into the test/diagnostics mode on this model?
I didn't check the bake igniter yet and from reading everything it seems like it's the most likely culprit here.
Thank you everyone ahead of time for your help.
Thank you everyone ahead of time for your help. Did you ever figure out how to get your oven into test mode? I'm trying to figure out the same thing.
