AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Can I change out the Freezer door, (without ice maker), with a door with ice maker?
Monogram 42” refrigerator Modle ZISS42NXBSS Serial RT030350
Can I change out the Freezer door, (without ice maker), with a door with ice maker? Where to buy?
Thanks, Patrick
If you were lucky enough to find all the required parts it would be possible but will be a lot of work and very expensive.
If you search AppliancPartsPros for ZISS42 and then look at units ( in the Matching Model Numbers section) that have a different letter than N as the next digit you will see that some of them do have in door ice makers but parts are missing prices etc. which usually means they are not available. |
THIS FORUM IS DEAD!!!!!!! |
