GWC
#1 Posted : Saturday, September 12, 2015 10:01:10 AM(UTC)
GWC
Aloha,
Wondering if anyone knows or can provide any assistance with this question.
I have a GE front loading washer on the bottom and a GE gas dryer stacked on top of it. I need to replace the door boot seal (Part #AP4334050) of the washer and have watched the video, which shows you need to take off the top and front panel of the washer. In order to get access to the top panel of the washer, I would have to disconnect the gas line on the dryer and lift it off the washer (I'm the only adult in the house).
So was wondering if it's possible to replace the door boot seal somehow, without needing to remove the top panel of the washer and just leave the dryer stacked on top? Is there a way to access and replace the necessary part of the washer without needing to remove the dryer on top?
Was hoping there is a way to do this repair and not have to disconnect the gas line and take off the dryer on top.
Thanks for any suggestions.
