I have a Kenmore Washer Model # 29532800 Serial # CW4430124. 2007-2008 vintage. In the Normal/Casual cycle the timer stops advancing halfway through the cycle and it just keeps washing and washing. If I use Delicate cycle the agitation is no longer slow but same speed as normal. The cycle will advance to completion in Delicate. Do I need a new timer and will it solve both problems? Thank you
Yes, I think a new timer should solve your problem as the machine otherwise is working.
