supercoach
#1 Posted : Sunday, September 6, 2015 1:29:02 PM(UTC)
supercoach
Hello:
My range / oven started to behave strange. One turned on no burner will heat (including oven or broil), however all corresponding lights are on, no error message. First time this happened several months ago, we waited several days and my wife decided to clean the oven. For whatever reasons it stated to work normally again. Today the same situation repeated. The oven stopped responding while in use. At this time no heat can be produced, at any department. Yet, all options, fans and lights on turning "on" when pressed. No error message.
I would appreciate any advise. Immediate thoughts:
- Fuse (but the over electronics most likely should not work in that case
- thermostat?
One more thing: when function (let us say a burner) is turned in "on" position, I can head very light sound (click) in the next 2-3 seconds...
Any help??? THANKS!
