the thermal overload kicks the compressor off. then resets and runs fine the compressor will run to satisfy the thermostat and the refrigerator is cooling properly but it does continue to kick off during a cooling cycle any help would be appreciated.
Need to pull the overload and the start relay to check for good continuity.
