We have a Kenmore ColdSpot Model 106.51562102 Side by Side refigerator that is failing.
I need the control electrical schematics. I opened the control panel to try and diagnose it and found someone prior to our ownership had butchered the wiring. I dont know what was taken out or bypassed but I have extra wires and cut and some just free with connectors.
I cant seem to google up schematic anywhere. It seems the parts are available but I dont want to invest too much without repairing the wiring properly.
for what its worth the symptom is a clicking of the relay on the control board when the door is opened. And the termination of the compressor run. which then has a delay before resuming. If you open the door too often this leads to temperature rise.
I hope someone can help! Thanks in advance.
Here are your parts Parts for Kenmore Refrigerator 10651562102 - AppliancePartsPros.comIf you go to the Sears parts site they have part breakdown diagrams bit do not share these with other vendors. See the attachment for your tech sheet. Also here is a manual which may be useful to you. You will have to join the site and be logged into be able to download it. The fan shut off and delay may be normal though I am not sure about this. |
THIS FORUM IS DEAD!!!!!!! |
