Grabow
#1 Posted : Tuesday, September 1, 2015 1:29:05 PM(UTC)
Grabow
With last use noticed that the washer beeped weird when the start button was pushed. when came back later to get clothes out could not open door. Did get door opened, clothes did not get any water. Trouble shot washer by cleaning water pump water screens where the water hooks up. We also unplugged to see if it would reset. We notice that the washer does 6 short buzzing noises coming from door lock once the start button is pushed and no water is getting in the drum.
Grabow
#2 Posted : Tuesday, September 1, 2015 2:08:00 PM(UTC)
Grabow
Ok tried washer again No beeps seems to be working again Assuming washer needed time to reset phew
Grabow
#3 Posted : Wednesday, September 2, 2015 4:07:45 AM(UTC)
Grabow
One cycle ran but since then same problem 6 short buzzes when door locks after start is pushed washer runs for maybe half cycle and stops. Door stays locked, no water getting to drum. Any suggestions would be greatly appreciated
