I have a cabinet next to my oven, and I accidentally put a screw through the cabinet and into the exterior wall of the oven. Now I'm worried about that being a fire hazard. I left the screw in place, so there isn't an exposed hole in the exterior oven wall. What do you think? Did I destroy my oven? :(
This should not cause a problem, though I would remove the screw.
I am assuming this is the oven exterior and not the oven cavity. |
THIS FORUM IS DEAD!!!!!!! |
Yes, it's the oven exterior and not the oven cavity. Thanks for the reply!
