moyakong
#1 Posted : Monday, August 31, 2015 5:18:13 AM(UTC)
moyakong
Good day,my model number is YLEQ5000PW0.
My dryer is heating normally but, my clothes are still damp i have to put it like 2 or 3 times but it still damp a littlebit, do you knwo what could be the problem? Ive checked on this website the section not heating, but mine is heating is just not drying my clothes. please help.
#2 Posted : Monday, August 31, 2015 7:26:35 AM(UTC)
Often this is a problem with the vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
moyakong
#3 Posted : Tuesday, September 1, 2015 1:27:43 PM(UTC)
moyakong
thanks i will try that!!!
