AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire stackable agitates, drains partly, no spin
Frigidaire gallery heavy duty top load stackable agitates, drains halfway, won't spin, lid lock doesn't engage
If you will post a model number someone may be able to assist you.
In the meantime take off the front panel and observe the machine when it is trying to drain and spin. Check the pump and drain lines for blockages and see if the motor and transmission are engaged during the spin cycle.
Washer Repair
