My door just started saying door open when I shut it. I am not getting any error codes only that. Anyone have a clue what it could be or how to check?
Here are your parts includes a wiring diagram. Parts for Frigidaire FASE7073NA2 / Dryer - AppliancePartsPros.comCould be a bad door switch. Check that it's contacts close when the door is shut with a meter. If you have an interior light, does it go off when you close the door? Could also be something wrong with the door latch re: not activating the switch correctly. Worst case scenario is that it could be a bad control board. |
THIS FORUM IS DEAD!!!!!!! |
I replaced the door switch and not working still. The light does not come on I don't think it ever did. What would be a next step to check from here?
