nitehawk92
#1 Posted : Wednesday, August 26, 2015 1:18:56 PM(UTC)
nitehawk92
My Dryer was squeaking badly, so I took it apart, replaced the belt, rollers and pulley. (The pulley wheel was loose, the triangle bracket was missing). Of course I had to take it pretty much completely apart to replace those things. I put it all back together and now I get a error code E1 on any setting that uses heat after about 1 minute of running. It will run indefinitely on No heat. I was not having any problems with E1 or heating before I took it apart.
I looked up the code and replaced the Thermistor. But I am still getting the E1 error. As far as I know I put everything back together correctly. Everything works fine as long as I do not use any heat settings. Anybody have any ideas before I give up and pay an arm and a leg to have it fix/replaced? Thank you...
