I have a Wpre6100g2wt washer it seems to be leaking from the bottom of the mode shifter. I am trying to figure out which part is bad. There is no water on the shaft itself and there is no water on top of the pulley. I just cant figure out how water is getting from the tub to the bottom of the shaft w/o water being everywhere else.
