jgwolfe
#1 Posted : Monday, August 24, 2015 8:26:03 AM(UTC)
jgwolfe
Hello, I have a Whirlpool Gold Accubake oven/microwave combo. When using the oven, the unit suddenly locks the oven door and boosts the temperature as if it has gone into self cleaning mode. The only way to manage this is to turn the breaker off and leave it off for about 30 minutes before restoring power. The microwave works perfectly.
Model is GMC305PDQ5.
I am unsure if I need to replace the control board (part #4456048) or the touchpad & control panel assembly (part #8300408). If anyone can advise it would be much appreciated.
#2 Posted : Wednesday, August 26, 2015 2:21:39 AM(UTC)
Parts for Whirlpool GMC305PDQ5 Oven - AppliancePartsPros.com
I would replace the control board as it is the more likely of the two.
Note that if you purchase it from AppliancePartsPros they will let you return it if it does not fix your problem.
Please see their return policy.
jgwolfe
#3 Posted : Wednesday, August 26, 2015 5:19:16 AM(UTC)
jgwolfe
Thanks denman. That's what I suspected but appreciate the guidance. I'll switch out the control board and hope that does the trick.
