My washer was making noise the last time we used it. It did throw an LE error my wife said. The next time it ran it blew the fuse on the main board. I replaced the board and now it make a high pitched noise without the drum moving like the motor it tring to move it but cannot. The drum jerks a quater of a turn at most then stops and the high pitched noise comes back and then jerks the other direction. I turned if off do not want to buy another $170 board. If anyone has any ideas on what to try next that would be very helpful.
