CPettey
#1 Posted : Wednesday, August 19, 2015 9:44:05 AM(UTC)
CPettey
My Kenmore front load washer intermittently does not run in high speed spin. I replaced the motor control board and still the same problem. I am wondering how the washer senses the balance as I think it may be some switch. I can not find a switch on the electrical diagram. Some loads run and some don't. should spin after tumble but shuts down. No error code but will be running diagnostics tonight.
Thank you in advance
Carl
sidfink43
#2 Posted : Wednesday, August 19, 2015 10:25:56 AM(UTC)
sidfink43
Changing out the speed control board is the most likely cure, so if that did not fix things the control unit is the next to try. If you buy from this site and the new control unit does not fix things you can replace it.
First check all the connections to the control unit. Try removing and reseating them. Not a likely solution, but it don't hurt to try.
