Power went out a couple days ago(i was not home when this happened) and then I noticed the next morning the Freezer and Frig were not cooling well enough. I unplugged it and plugged back in and it does not sound like the compressor is kicking on. Frig temp is mid 50's and Freezer temp is mid 40's. Please help. Thanks
Check the start relay and the overload, both located on the side of the compressor. These often fail after power surge.
