Noticed that the control panel on front of the fridge was not on. When holding the power or lock button everything lights up. If you try to get ice or water the fridge will beep at you. Interior lights work when door is open. I do not hear the compressor turn on and the fridge is not cooling
I am looking for a wiring diagram for this fridge specifically power going in and out of the master control board. I would also like to now if I can get a wiring diagram for the capacitor and controller.
Will be calling Sears to check in we still have a warranty on this. In the mean time want to know what I am dealing with.
Thanks for the help.
Here are your parts Parts for Maytag MFI2569VEB2 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. If the fans also are not running you may be stuck in a defrost cycle as it shuts the compressor and both fans off. How long have you waited? A defrost cycle lasts for about half an hour. Have you tried unplugging the unit for a few minutes to see if it will reset itself? |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts Parts for Maytag MFI2569VEB2 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. If the fans also are not running you may be stuck in a defrost cycle as it shuts the compressor and both fans off. How long have you waited? A defrost cycle lasts for about half an hour. Have you tried unplugging the unit for a few minutes to see if it will reset itself? Thank you for your help. I unplugged the fridge last night for 30 minutes and plugged back in. Nothing happened. Would being stuck in a defrost cycle cause the front control display to be off? If I hold a button on the front display, the display lights up but does not display numbers or letters. It will only display generic 8's and 0's.
[COLOR="Blue"]Would being stuck in a defrost cycle cause the front control display to be off?[/COLOR] No |
