The dryer works fine and suddenly it stops working. When I press and hold START button, it runs and rotates; once I release the START button, it stops.
I checked all 3 fuses (500--Safety Thermostat (thermal Fuse), 500--Thermostat (4-Wire), 530--Hi-Limit Thermostat, ) near the drum, and they are all good.
What is my next step to find which part is bad? Your expertise will be appreciated.
Please remove this thread. I think I posted twice. thanks.
