AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Sears/ frigid airs front load washer not going into high speed spin
Machine does not go into high speed spin. Checked Internet and many people found that door latch switch was culprit. Replaced that, no go. Replaced timer, still no go. Problem is intermittent. Could it be speed controller? I figure if speed controller was bad it would not work at all?! Any suggestions?
Washer Repair
