I'm unsure of the age of my range, but it is a Whirlpool Super Capacity 465, model number GS395LEGQ7.
After a brief power outage last week during the night, the burner ignition and oven gas/ignition have stopped working. The digital controls are working and the burners are being supplied gas and can be lit externally. There is no error code or any sign that there is something wrong.
I've looked around but I have not found this combination of ignition problems, so far, everyone has either a stove top ignition or oven ignition issue but not both.
I'd appreciate some direction since at this point it seems like there are several parts I could replace based on common fixes but I don't want to replace everything and have it be something else.
Thank you.
Could be the spark control module, expensive part to replace though.
