dukfootball
#1 Posted : Monday, August 3, 2015 7:36:24 PM(UTC)
dukfootball
Exactly the same issue as described here:
http://forum.appliancepartspros...itchenaid-oven-dies.html
(oven heats up in bake mode then switches to clean cycle. Oven locks.)
I've turned off power to the range. I would like to check the fuse suggested at the end of the post. Would I just get an "OL" reading on my Multimeter, if the fuse is bad?
Thanks for the assist.
Chris
