cdm1948
#1 Posted : Monday, August 3, 2015 6:58:52 AM(UTC)
cdm1948
I have notices small beads of styrofoam on the bottom shelf of the refrigerator since it was installed. Until now there have only been a few pieces occasionally. In the last couple weeks the amount has increased and I have to clean them out daily. The refrigerator is cooling correctly so I hesitate to pay someone to come out. Does anyone else have this issue and do I need to have it fixed or just tolerate it?
CletusT
#2 Posted : Monday, August 3, 2015 8:13:06 AM(UTC)
CletusT
Could be;
1- loose beads from factory if it is fairly new
2- beads from styrofoam housing where diffuser enters refrigerator compartment
3- beads being knocked loose from area where evaporator fan is installed
In any case, I doubt it is anything serious, and I would bet it will stop sooner than later. If a fan blade were causing the problem, you would hear the fan grinding against the foam.
