katflea
#1 Posted : Friday, July 31, 2015 4:46:04 PM(UTC)
katflea
When dryer heats..... the circuit breakers "trip".
It does not trip on "no heat" cycle.
Do I replace the thermostat or the element??
katflea
#2 Posted : Saturday, August 1, 2015 1:04:03 AM(UTC)
Parts for Whirlpool LEQ9858PG0 Dryer - AppliancePartsPros.com
Of the two parts the heating element is more likely.
You would be better of measuring it with a meter.
Unplug the unit.
Disconnect both sides of the heater.
Measure the heater should be between 8 and 12 ohms.
Then measure from each side of the heater to it's case, both should be infinite ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
