I took out the glass shelf assembly to re-install it, and had to clean the glass piece. It came out of the wire assembly fine, but now I can't get it to stay on? U It keeps slipping out through the wire holder. Part no 297324500.
Any help appreciated.
Never mind figured it out. I has to slide the glass into the slot running along the plastic piece that is attached to the front of the shelf. That is what holds the glass in.
