jim baker
#1 Posted : Thursday, July 30, 2015 9:31:59 AM(UTC)
jim baker
dual evap side by side sweating left food side wall.replaced food gasket,freezer sensor and computer.temp at correct now,not too cold fz 2deg 38 fd. still sweating??
CletusT
#2 Posted : Tuesday, August 4, 2015 9:25:07 PM(UTC)
CletusT
Check the diffuser and vents to ensure proper air circulation, then check to ensure light is going off when the door is closed, you can check it in the dark by cracking the door, or remove the bulb and see if that changes anything.
Some models are notorious for bad light switches.
