Good Morning.
My daughter stepped on an open dishwasher door. I now have no spring resistance when the door lowers, and when I slide out the bottom rack, it is no longer a smooth slide, I have sort of a "speed bump" when I hit the door.
I figure I will need new springs. My questions are:
1) What springs to order? 2) How do I know if I need new hinges? If I need to order, what do I order? 3) How hard is this repair? 4) Do I need to remove the stainless cover from the door? 5) I have found the videos for spring replacement and spring link replacement, but haven't found one for hinge replacement if I need that.
Thanks!
Sorry, here is the correct one...
Mod: WDT710PAYM5
