Condenser is clean, coils are frost free, compressor is running but both fridge and freezer temp is around 60 degrees F oh and both fans are running it is a side by side Frigidaire model GLHS65EHW
Remove the cover in the freezer so you can inspect the evaporator coils. Be sure that the compressor has run for at leeast half an hpour. If you check the coils during or shortly after a defrost cycle you may come to the wrong conclusion.
If the coils have no frost or just frost in one area then it is a sealed system problem.
This will be an expensive repair. Often it makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
