FixerNot
#1 Posted : Thursday, July 16, 2015 10:01:48 AM(UTC)
FixerNot
Oven control quits after 30 minutes or more and goes blank and oven is inoperable. After cool down it can be reset and works for a short time.
Oven door is fully closed, control panel is warm and can be touched with out a problem. No heat distortion of control panel.
Does the cooling blower on top of the oven ever come on during normal oven operation or only during self cleaning? Never used self cleaning. Both temp sensors on top of oven have been replaced.
Simon / APP Team
#2 Posted : Thursday, July 16, 2015 9:33:33 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What I think is happening the cooling fan doesn't come on at 155 degrees as it suppose to (may be because the fan thermostat is faulty or the fan motor winding burnt) and the hi-limit thermostat opens, cutting the power to the controls. Then when the temperature drops down the hi-limit closes restoring the power to the controls.
The bad news are - the cooling fan and the thermostat are no longer available
Here are the breakdown diagrams and parts list for your range:
Model ACS3350AB
Thank you,
Simon.
