psfarley
#1 Posted : Sunday, July 12, 2015 9:49:52 AM(UTC)
psfarley
just replaced the bellow because it was stopping and leaking. Also replaced the striker. now it's stopping in the middle or end of wash cycle beeping. I have to drain and either try to start over or move it to rinse cycle. what could be the possible issues?
sidfink43
#2 Posted : Monday, July 13, 2015 6:32:10 AM(UTC)
sidfink43
The two main suspects are the control unit and the door lock assembly. I think it is more like the door lock assembly, that something happened to it when you were changing out the bellows. See if you can use the tech notes that are under the top or inside the lower service panel to do some testing and diagnosis.
