Suddenly lost all power. Checked the outlet and it was good. I removed the cover on the bottom rear and found the compressor very hot, with a slight burnt smell. Left the fridge unplugged till the next morning. Then plugged it in and my screen shows flashing zeros. I thought it was the compressor at first but now not so sure?
Groups: APP Team
Hi, Bruce. At the back of your refrigerator on the right there is a metal plate covers the main control board. Unplug the fridge and remove the cover. Unlock the clips and pull out the board, turn it over and ... you might see the reason why the fridge doesn't work. If there is a burnt spot on the back of the control it must be replaced. The control board Part number: AP5324215
If the control board looks "like new" then the problem is most likely with the inverter board that is mounted next to the compressor The inverter Part number: AP5669522
Here are the breakdown diagrams and parts list for your refrigerator: Model PFCS1RKZASS
Good luck. Please keep us posted with results. Thank you, Simon.
The board does have a blackened area. So it must be fried, will change and see what happens. Thanks njbruce
