The Dishwasher Runs All Cycles Ok But Whenit Comes To The End Leaks Copiously. Several Local "repairmen" Checked It And Cannot Find The Leak. I Don't Have The Installation Maual. Think It May Be The Corrugated Hose Cracked (but Not Visible). Appliance Is Properly Leveled. 1) What Could It Be? 2) Where Can I Dowload An installation Manual (not User Manual)
Here is the install manual http://shared.whirlpoolc...erature/JDB4950AWFII.pdfThis should also be useful http://www.servicematters.com/m...ibrary/docs/16009308.pdfHard to say where it is you may have to pull the unit out to find it. I would unplug or flip the breaker to remove power from the unit. Reach back and dry the unit off as best you can. Then run a cycle to try and find the leak. A small mirror and a good flashlight are very helpful here. The type of mirror that is on a handle like the ones a mechanic uses are ideal (a lager version of a dentist's mirror). You could just tape it to a piece of doweling. I do not like sticking my arms under a unit when it is running. |
THIS FORUM IS DEAD!!!!!!! |
