frodo
#1 Posted : Tuesday, July 7, 2015 11:43:12 AM(UTC)
frodo
UserPostedImage
UserPostedImage
little help with the wiring please.
the middle wires blue and white with red strip, is the 120 volt power
can I change the speed of this motor by using
the black wire [next o the blue]
or the blue with yellow strip [next to the white with red] ?
what are the red wires for?
I am trying to lower the rpm of this motor
thanks for your time :D
fairbank56
#2 Posted : Tuesday, July 7, 2015 2:04:45 PM(UTC)
fairbank56
Groups: Expert
This is a single speed motor, you cannot change it's speed. The red wires are for switching the dryers heat circuit off when the motor is off via it's centrifugally operated switch.
Eric
frodo
#3 Posted : Tuesday, July 7, 2015 3:36:04 PM(UTC)
frodo
thanks for the answer, I am making a brass tumbler.
figured I would check if I can change rpm by wires before I change by pulleys
