My washer has a digital control panel and when I press any of the buttons, nothing happens, it's like a fuse has blown. Can you tell me what part I need to order?
Groups: APP Team
Hi.
Check if there is power going to the washer. Then open the control panel and disconnect the flex ribbon that is connecting the touchpad to the control board from the control board connector and clean it with a cotton swab soaked in alcohol. Check all other connectors, make sure they are properly seated. If this is not going to help you should consider buying a new washer because all major parts are no longer available :(.
Thank you,
Simon.
