chefpels
#1 Posted : Wednesday, June 24, 2015 11:16:19 AM(UTC)
chefpels
GE Arctica refrigerator/top freezer
Freezer keeps defrosting/melts down, probably 3 x per week.
when it kicks back in, freezes quickly.
Have done the following:
- vacuumed and blew out coil.
this seemed to work, but it did melt down a few days after doing this.
wondering if unplugging and plugging back in had more to do with
'fixing' the unit than blowing out coil
- pulled off panel from inside freezer to check freeze up on the fins - negative
- no waterline or ice maker attached.
- right now, as i open freezer door can hear no sound whatsoever, so can't tell if fan and/or condenser is running. they both work, just intermittently as the unit does re-freeze.
at this point do i purchase a new one or is this an easy enough fix to warrant a repair?
#2 Posted : Thursday, June 25, 2015 5:46:01 AM(UTC)
Parts for GE PTS25LBMARWW Refrigerator - AppliancePartsPros.com
I do not have access to GE tech data so have to do some guessing.
It sounds like it may be a defrost problem re: unit is not shutting off the defrost heater after the iv=ce has melted off the evaporator coils.
At the top of my list would be the evaporator thermistor.
Next would be the control board.
Below is a link to a manual explaining how GE does defrost.
You will have to join the site and be logged in to able able to download it.
http://appliancejunk.com...wnloads;sa=view;down=315
This site has other manuals on GE units which may be useful to you.
Freezer/Refrigerator - FREEZER keeps defrosting (Refrigerator & Freezer Repair)
by kskermit 4/16/2013 6:07:33 PM(UTC)
Freezer keeps defrosting! Help! (Refrigerator & Freezer Repair)
by papabear1245 4/13/2013 7:01:13 PM(UTC)
Freezer keeps defrosting (Refrigerator & Freezer Repair)
by kathydunn98 11/14/2012 7:49:27 AM(UTC)
Refrigerator/Freezer keeps defrosting (Refrigerator & Freezer Repair)
by Nancyd 12/29/2011 12:42:30 PM(UTC)
