wvirnwkr
#1 Posted : Wednesday, June 24, 2015 4:08:06 AM(UTC)
wvirnwkr
Normal cycle green light on control panel blinking. Unit wil not run. Water in bottom did not empty. :confused:
Simon / APP Team
#2 Posted : Wednesday, June 24, 2015 4:10:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is a short in the touchpad circuitry.
If you remove the kick panel you will find the tech sheet inside the pocket at the back of it. Go to "Checking keyswitch contacts" and perform the test.
Here are the breakdown diagrams and parts list for the dishwasher
Part number: DU1100XTPQ7
Chose the correct color for the control panel or the control board on the diagram # 02.
Good luck. Please keep us posted with the results.
Thank you,
Simon.
