JasonLofton
#1 Posted : Monday, June 22, 2015 3:46:18 AM(UTC)
JasonLofton
Had a clogged drain, dishwasher stopped draining. I pulled dishwasher out to see if water had overflowed to pan, which hadn't. Ran a cycle and it completed cycle but still had some water. Pulled it out again, got ready to run cycle and now when I shut the door all the lights go out? There is no error code flashing...initially all the lights were flashing but I was able to seemingly reset but now I have the above problem. Still don't know if it will properly drain.
