joshhaye44
#1 Posted : Saturday, June 20, 2015 11:11:50 AM(UTC)
joshhaye44
My Duet dryer is acting up on me. When I turn it on and push start the sensing indicator lights up but nothing happens. Just sits there. I have run diagnostics and get the 6E code. I have replaced the thermal fuse and thermitor and have checked continuity on all the relevant parts. Next up is to replace the sensing bars. Anything else I should try? Thanks.
fairbank56
#2 Posted : Saturday, June 20, 2015 11:31:20 AM(UTC)
fairbank56
Groups: Expert
Replacing the sensing bars isn't going to do anything. If you've checked the thermal fuse, belt switch and door switch, then it looks like you have a defective control board.
http://www.appliancepartspros.c...d-8546219-ap3775548.html
Eric
