Larry Dover
#1 Posted : Thursday, June 18, 2015 11:15:51 AM(UTC)
Larry Dover
The refrigerator dispenses water but no ice. I see a steady green light on the ice-maker. I do not detect any water or ice in the ice-maker. Do you think all I need to do is replace the ice-maker or should I look for other issues?
Simon / APP Team
#2 Posted : Thursday, June 18, 2015 12:03:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Larry.
Before replacing the ice maker, you need to make sure the water inlet valve is not faulty. Check if the ice maker fill tube is not frozen. If it is, the inlet valve should be replaced. In case if the fill tube is not frozen, get to the rear of the refrigerator, remove the cover at the bottom and locate the dual water valve. The smaller diameter tube is going to the ice maker. You will have to switch around the electrical plugs on the control coils, most likely you will need to use a zip tie to hold the plug on the red coil. Make sure it's making a good connection. Next, press the water lever at the dispenser for six, seconds, then open the door and check if there is water inside the ice maker. Water comes in - replace the ice maker. No water - replace the water inlet valve.
Here is a breakdown diagrams and parts list for your refrigerator
Model PSS27NGPACC
The water valve Part number: AP3192626
the ice maker Part number: AP4345120
Good luck. Please keep us posted with the results.
Thank you.
Simon.
ice maker not working....low flow on water dispenser (Refrigerator & Freezer Repair)
by vince mac 2/6/2013 7:38:02 AM(UTC)
Ice Maker not working. (Refrigerator & Freezer Repair)
by CARTWRIGHT88 4/4/2012 4:25:21 PM(UTC)
