Dcovey
#1 Posted : 10 years ago
Dcovey
Close door, latch the door turn on dial to start washing mode it clicks but no water and nothing happens, breaker is ok and electrical connection seems ok, could it be in dial system ?
Simon / APP Team
#2 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Hi.
Please look at the breakdown diagram Model GSD2220F00BB
Start with checking if the water shot off valve to the dishwasher is open! It should be under the sink.
Next, at the body parts diagram find the float and float switch in the left front corner. In case if the float will stock in an upper position or the switch lever is not pressed, water won't fill in.
Remove the kick panel and check the switch and float position. Also, check if the pump motor is making humming noise when the dishwasher is turned on. The motor could be jammed. If it is, unplug the dishwasher and manually turn the motor by its fan to release the shaft. You may succeed or may not, depends on how bad is the jam. The click you are hearing is most likely the drain solenoid activating.
If the float and float switch are both OK check the water inlet valve. If you have a multimeter and know how to use it, check if there is 120V AC going to the water valve solenoid terminals in the first two minutes of the wash cycle. If there is a proper voltage to the valve and water is not coming, replace the inlet valve.
Please keep us posted on the outcome.
Thank you.
Simon.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
High-pitched noise with LG dishwasher (Dishwasher Repair)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 11 months ago
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 12 months ago
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 12 months ago
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace about a year ago
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr about a year ago
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest about a year ago
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
