jrnutpaul
#1 Posted : 10 years ago
jrnutpaul
I started this washer using 'normal' with a 'hi-temp scour' the washer ran and when i went back to empty it the 'hi-temp scour' light was blinking. I checked the heating element and the continuity was fine. I check the control board,the drain pump, put it back together. No lights were blinking.
I pushed the 'normal' button and it's light started blinking. I pressed the cancel button and it's light started blinking. I pushed the 'air dry' to reset but it didn't. when I turn off the power and turn it back on...no lights blink. I push 'normal' and it starts blinking again
