syoung03
#1 Posted : Friday, June 12, 2015 2:34:31 AM(UTC)
syoung03
We have an older upright freezer. 2 weeks ago we moved it to a different location and now the freezer is no longer cold and the door doesn't have suction. The motor seems to be running but the air coming out is cool, not cold. Any idea what might be wrong? Does the date code below mean Sept 4, 2005?
Sarah
United Commercial Heavy Duty
Model: UCFF201 A0
R12- 9.2OZ 260.8G
115 Volts 60 Hertz 4.0 Amps
Type: FSSC-AURW250
Date: 9405
Design Pressure High: 240psi, Low: 95psi
Jeff / APP Team
#2 Posted : Friday, June 12, 2015 7:26:14 AM(UTC)
Jeff / APP Team
If all fans are running, and the compressor is running, then it sounds like you may have sealed system failure with the unit. Check and see if the evaporator coils have an even frost pattern. If not, you will need an HVAC tech to repair the unit.
