Hey,
New to the site, looking for some help, please and thanks.
The oven wont work, I checked elements, thermostat, can't find anything wrong.
I read that there would be an error code, but there is none on the display??
I know the system works because I forgot to plug the thermostat back together and I got a code F30, which is open connection, plugged it in and the error code went away...help!
Here are your parts Parts for Frigidaire CFEF312GQA Range - AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/p...ingfield/316458436en.pdfSounds like a bad control board. I am assuming that the stove top elements work OK. You could unplug the unit and check L2 out to BK and BRL for continuity at the control board. This checks the elements and their wiring. Also check L@ to L2 at the terminal strip. If all OK then I would say it is the board item 20 in section 03. You may also need an overlay (item 20A) as often they get ruined when trying yo remove them. Note this depends on whether it is peel and stick. I cannot tell which type you have. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the info denman, yes the stove tops work, and I will check for continuity. But why no fault codes?
[COLOR="Blue"]But why no fault codes?[/COLOR] They just do not monitor everything. The elements and power to them is not checked. It does monitor the oven sensor but even there they just check if it is shorted or open. This is the norm in the industry. |
OK. Thanks for all the help.
