Ahhh help water on floor. I need to replace the drip pan its cracked. Can't get it out. How do i get the pan out? Front plate looks like it wedges into side panels of refrigerator. What a pain. I could use some advice
Figured out this pan is removable only by raising refrigerator up onto blocks. The tray is held in with a hex bolt on left center. Comes out easily after that.
Part# for new Drip Pan: 241683601
Tips: Empty fridge of breakables. Use big husband to tip fridge while wife puts blocks under feet. Place a catch under drip hose until new can be installed.
