The fan is working, but i hear the compressor kicking on and off. It does not stay on.
Check the compressor windings for resistance, continuity and that they are not grounded. Below is a link on how to do this. How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.comThe above can tell you if a compressor is bad. It does not tell you that the compressor is a good as it may have internal mechanical problems. If the unit has a relay type start device it is also covered is the above link. There is not a good way to check a solid state start device so you basically have to but one and try it. |
THIS FORUM IS DEAD!!!!!!! |
