SEPAZ
#1 Posted : Saturday, May 30, 2015 11:37:34 AM(UTC)
SEPAZ
Thanks to the helpful videos on AppliancePartsPros.com, I've been able to replace the clutch, transmission and basket drive and brake on my washer.
Can't find any info on replacing the timer, however. I'm sure it's fairly simple, but I like having curly-haired Matt as a wingman. Anyone know where I can find guidance?
Thanks,
Scott
sidfink43
#2 Posted : Sunday, May 31, 2015 5:13:59 PM(UTC)
sidfink43
If you take off the back of the control panel there should be instructions on how to remove the knob, unless it unscrews in which case that's all there is to it. From the front there are screws that hold the timer on. Simply unplug it and replace it.
