MediateFirst
#1 Posted : Tuesday, October 27, 2009 3:17:25 PM(UTC)
MediateFirst
Element won't come on. One of the two cutoffs tested bad. New part... element went on...when too hot, new cutoff opened but when cooled down wouldn't close again. Question: is there any way this could happen if cutoff (3977393) is not defective?
#2 Posted : Tuesday, October 27, 2009 4:44:59 PM(UTC)
Replacement parts for WHIRLPOOL LTE6234DQ1 | AppliancePartsPros.com
Take a look at Item 47 in Section 4.
The 309 degree thermal cut-off is actually a thermal fuse so once it blows it will not reset.
That is why it is sold with a new hi-limit thermostat,.
So if your cycling thermostat's contacts should weld themselves closed, the heater will cycle on the 250 degree hi-limit and not blowing the higher temp thermal fuse. You hopefully would notice that the unit is running too hot and check into it before the hi-limit contacts also weld themselves together and bl;ow the thermal fuse. At least that is the theory.
Note always check/clean your vent system when a thermal fuse blows.
It sounds like you may have a grounded element. The element has sagged or broken and is touching the case/frame so it runs unregulated. Often you can see this by inspecting the heater.
A better check is to use a meter.
Unplug the unit.
Remove both wires from the heater
Measure it, usually around 10 ohms
Then measure from each connector to the case, both should be infinite ohms.
MediateFirst
#3 Posted : Tuesday, October 27, 2009 6:35:47 PM(UTC)
MediateFirst
many thanks. Will try your suggestion.
