YankeeDoodle
#1 Posted : 10 years ago
YankeeDoodle
When the ]"wash.rinse" control settings are on "hot.cold", "warm.warm", "warm.cold", only HOT water enters during the fill cycle.
When set on "cold.cold", no water fills the washer.
Is there a temperature selector switch on this model that could be the culprit?
If so, what is the part number and how difficult is it to replace?
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
Model number doesn't come up, assume this is an LAT9605 ? Swap the electrical connectors between the hot and cold valve solenoids and see if you get cold water when hot is selected. If not, screens could be clogged, valve assembly may be faulty or you have no cold water supply. In regular cycle, does it spray at any time during spin cycle? If not, the problem is not the temp switch.
Eric
YankeeDoodle
#3 Posted : 10 years ago
YankeeDoodle
Hi Eric:
I took your advice and cleaned the screens; works fine now.
Many thanks
