kennow
#1 Posted : Friday, May 22, 2015 8:34:09 AM(UTC)
kennow
The rinse agent dispenser is not working. Our dishes are not drying completely and we noticed the rinse agent dispenser stays full. Any help would be greatly appreciated!
Simon / APP Team
#2 Posted : Friday, May 22, 2015 11:29:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Kennow.
First I'd like to clarify if you chose the "Heated dry" cycle? If you did - unplug the dishwasher, remove the toe panel, locate the heater contacts and using a multimeter check continuity across those two contacts (with one wire removed). If there is no continuity you heater is bad and should be replaced. Here is the part number AP580976.
Thanks,
Simon.
rinse agent dispenser not working (Dishwasher Repair)
by russv1322 10/23/2010 1:35:46 PM(UTC)
